Based off the picture you have given, I believe you have a misunderstanding on what components you are dealing with. If I’m wrong, please correct me.
1. Is the Overlimit valve system, it should be a screen in the center and held in place by a “Washer” that is secured by peening the Piston head material in place. I don’t see any damage, if so please attach a better picture. I would not even mess with the components unless there are problems, normally pretty bulletproof.
2. Is the Heel plate, it gives #3 a solid base to rest against.
3. Is remnants of a Ucup, it’s job is seal the cylinder and allow the jack to build and hold pressure. Once you remove the old pieces, it will release the heel plate and washer underneath.
