Walker Turner 36" Wood Lathe
BrianFL
I Would like to know what kind of lubricant I should use for the bearings. the ports are screw off and i am assuming that its for some weight of oil. Also it has a Century Electric Single phase motor and it has two flip top oil ports. What weight oil would it take?
Mr_P
Tinley Park, IL
Not sure about the oil weight. Maybe some wheel-bearing grease?
I just bought one and would like to post a pic. Might be from the early 1930's Do you have pics of yours?
tombell572
Sea Cliff, NY & Portland, OR
Generally, machine spindles running in bronze sleeve bearings or in a cast iron boring functioning as a bearing would take a light spindle oil such as Vactra 2 or an equivalent--same for the motor. Grease typically would not reach the entire spindle running in the bearing and is best reserved for ball and roller bearings.
Tom B.
