Walker Turner 900 DP slow speed pulley rebuild help
Tano
Staten Island, NY
Before I start I want to mention that I did a search the forum and did not see any threads specific to rebuilding the slow speed attachment for a WT900.
I was hoping someone has had success removing the bearing/pulley from the shaft. I have a set up that I was hoping to change the bearings on, but after doing some research, there seems to be an odd C-Clip in the middle of the casting stopping the removal of the second bearing. has anyone had any luck rebuilding one of these units?
To save some time, I am not looking for alternative low speed options as I have other low speed set ups from delta and Craftsman that I can use . I want this particular rebuild to be accurate.
Thanks
Tarnished
SW Ohio
Tano: Can't help much on the bearing retainer but have you checked here. "OWWM". I think this post may help with what you're working on. Lot of hits with search.
Good luck! Those WT 900 are nice machines.
crguy
SW Washington
There has to be a way to take it apart without damaging it. Can you see the clip? Do you need a tool to get it out?
