Boulderdash
FNG/Newbie alert!! I'm a long-time lurker of Garage Journal who's only recently joined, and thought that, having virtually finished my Walker Turner bench drill restoration, some of you guys might appreciate it if I made a step-by-step thread detailing how I got on. I welcome your feedback and advice, good or bad!!
I should firstly mention that I am in the UK, so it's rather rare indeed to come across one of these lovely old bits of machinery. So you might guess my surprise and elation upon not only discovering one locally for sale (practically next door from work!!), but also at the princely sum of..........£10 (around $13)!!! The deal was swiftly done and the drill was home and totally stripped apart, down to every last nut and bolt.
I have the good fortune of working at an engine machine shop, which amongst other fantastic old machine tools, has a parts cleaner for engine parts and oily bits. So the drill base, pillar, head, motor plate and table were all sent through for a wash to strip the old paint off and remove a decade or so of grime
I used my Myford ML7 lathe to dress and restore the spindle, turning it between centres. It carries 4 holes for extraction of the chuck, which appeared to have become rather chewed up in the past. So I turned off a few thou of the outside diameter to clean it up. I also used the lathe in a similar fashion to clean up the bars that hold the adjustable motor plate on, and the splined axle for the hand crank. These parts I finished off with emery paper by hand.
