wall covering?
jkonces
so when i bought my house in colorado it has a finished garage with drywall and painted, the previous owner built some real sketchy shelves throughout the garage, i ripped them off the wall where all of my fab stuff is going and need to figure out a way to cover the holes up. i know i could repair all the drywall but i do almost all metal fab in my garage and at my last place welding slag and sparks tore up the drywall anyway, so im looking for a cost effective way to panel over the drywall, protect against sparks and slag and look decent, any ideas? i was thinking of getting thin plywood and fastening it to the studs and calling it good but please help with some input? thanks
JC23
Northcoast
OSB will be stronger than thin ply and you can paint when it needs it.
But you aren't welding everywhere against the walls are you? If you have a designated weld area, maybe some metal on the walls would work there.
NUTTSGT
Northern Central Ohio
Iwas going to suggest some aluminum diamond plate on the walls where you are welding. It'll look nice and be resistant to the welding splash/berries.
