Wall mounting NEWAGE cabinets
Dentaltec
Redlands Ca
I am looking for the easiest path to get these heavy cabinets wall mounted, I know a bunch of you guys wall mounted them I was hoping some of you would share your tips and tricks.
I was planning on a ledger board to rest them on but maybe there is an easier way? The big locker cabinets are pretty heavy
Thanks
driftpin
I mounted 30" x 30" x 12" welded-steel Gladiator cabinets onto a cbs wall using tapcons w/stainless-steel flat washers, one tapcon in each corner. Yes, I did use a ledger, probably not necessary.
D
Dentaltec
Redlands Ca
Was hoping someone had some sort of non muscle it up technique they could share with a slick simple engineered way
phanttom
Alberta
I put one up at a time. The first one was the hardest. Once one is up you can boot cabinet to cabinet to take the support of the new one as you fasten it to the wall
