Wall paneling ideas?
speedminded
Atlanta, GA
Practically 1 in 5 posts is questions regarding flooring but what about the walls? I'm trying to determine the best interior alternative to the usual drywall for my detached shop/garage and, due to the expense, i don't really like the idea of trial and error...
The first option was the same reverse board & baton that's on the exterior, not quite as boring as plain plywood, cheaper than individual boards, but it would still look like a yard shed on the inside...I think even if i did a wainscoting with it painted in two differant colors. Trying to avoid wood though: will be doing some cutting, welding, and grinding. Anyways, browsing Home Depot today I found slick paneling used in bathrooms and kitchen back splashes. One was plain & slick, I've used it on the walls above showers before, but they also had a few with patterns too: 4" tiles and a couple others....Anyone use this in a shop or garage before?
On the shop side I'm thinking about doing a chair railing with the reverse board & baton below then the 4" tile up to the ceiling and on the ceiling (It currently has 80's wood paneling all over). Will be doing minor metal fabrication: metal brake, slicer, couple large benches, drill press, etc...nothing too messy. See my sig pics for the spoiler & splitter i made on my car.
The garage side is going to remain open trusses, painted black, with the silver corrugated metal above it but not too sure on the walls yet. The entire building has several windows, plus the ones in the overhead doors, so the walls don't necessarily need to be white...just a lighter color would make it appear to be larger. The garage side will be used for everyday parking and very regular mechanical work: tool box or two & a roll cart, engine stand, table for tearing apart a transmission or engine, parts washer, sink, etc.
I want it to be spotless though, not quite sterile like a lab but just clean...similiar to the race trailers or under the awnings of the Le Mans series teams. Throw up the 4' x 8' Ferrari flag, a few others banners, and all my Road Atlanta race posters (framed of course) and call it good. A bar and a projector showing vintage races on the wall while working on the cars would be nice :)
Pre-remodel pic...
S
speedminded
Atlanta, GA
...I feel like i'm talking to myself. Was in Lowe's yesterday and they carry brushed "stainless" panels, I think the tileboard style would look good on the bottom 4 feet but that stuff is $21.00 a sheet, ugh!
http://www.decpanels.com/metallics.html
Wonder how a cherry or similiar wood paneling on the ceiling with recessed lights would look?
Luckydevil
Tampa
I like that brushed stainless wall paneling, that would definitely save some space and show off some of the nicer tools.
Tim240Z
LAX area, So Cal
:wtf: In the photo above, I am wondering what the heck that dude is gonna run (tools wise) with that silly little pancake compressor :headscrat
gp_frk
Texas
Duh he's gonna run the impact thats hooked to the hose lyin on the bench :wtf:
Cebby
Pittsburgh, PA
I have a twin tube portable that doesn't drive my impact worth a hill of beans. You need more power to use an impact effectively.
AV8OR
Somewhere Over America
Going to be "doing some cutting, welding, and grinding" eh. Have you looked into using Hardipanel Vertical Siding? Ask your insuance man if your fire insurance on the shop will drop because they should consider consider it masonry.
The smooth side should give you the look you are looking for.
kd5lef
Tulsa,OK
Just an observation here - but its prolly one of the 4hp porter cable jobs (judging from the drill and nail gun on the wall) They usually keep pressure well and have a good recovery rate. If'n he doesn't use it all that much it may work well for him.
I do like the floor and peg board though.. nice touch.
gp_frk
Texas
guys I could be wrong here but that pic looks a little toooo staged to be an actual shop pic. It looks like and add for those panels to me. If not then my mouth is wide open waiting for foot insertion.
Luckydevil
Tampa
The second pic is definitely an ad. I don't think he is saying that is his garage, just showing a pic of what he is talking about.
TimB
Kearney, Mo
I used steel "pro-Panel" like the outside of a metal building has. I compared it to the price of OSB and paint and it was a lot less. I went with white. I like the hose-out-ability of it but grinding/welding sparks do tend to rough it up some. Makes for a clean working shop, but probably too rustic for a show shop.
TimB
Kearney, Mo
Here's a pic from before I got all my **** moved in. There is 1.5" of air space and 1.5" styrofoam insulation behind the tin. The tin only goes up 8' and the styrofoam is exposed above that. I would like to have gone all the way up with the tin but cost is a factor for me.
gp_frk
Texas
I was refering to the comments later in the post about his use of the air compresser. BTW this site kicks A$$
96MysticSVT
Austin, TX
With the high humidity and wood eating insects being my 2 biggest problems in central Texas, I went with Hardi-panel. It looks identical to drywall, but since it's made of concrete it's impervious to moisture and insects. If you put a hole in it, you can patch it with drywall mud.
