colin.mitchell.129
- Joined
- Sep 18, 2015
- Messages
- 13
In the middle of installing my beacon morris 45k btu garage heater. I'm horizontally venting with 4" cat iii pipe. Just making sure I get the wall thimble correct. It says on the sticker that it needs 8" clearance to combustibles. Essentially it's a 4" pipe going through a 6" pipe(thimble) so does that mean I need 8" clearance from the edge of the center of the thimble? The wall I'm going through is 16" on center studs with 3/4" wood paneling, fiberglass insulation, plywood, then vinyl siding. I was planning on going through the middle space between 2 studs and using a 6" hole saw all the way through. Secure the the thimble on the inside by screwing to the wood paneling and on the outside cutting away the vinyl in a square so the thimble sits flush to the plywood then screwing it down. Does this sound correct, or do I need to make bigger clearances?
Sent from my SM-N910V using Tapatalk
