xrdad
For some reason, I'm not getting many replies on my build thread.. I don't think the thread is coming up under 'new posts'? (Sutton Shop)
Anyway, here's the deal:
30x40 shop, 13' ceiling, one 12x12 door, one 16x8 door, 2 man doors, one 4' window, 6" slab in central Ontario Canada.
I'd like to go with radiant heating in the slab, which will be poured next spring. The shop should be standing in about 2 or 3 weeks. Frost walls (8" CMU, 8 runs, 4' deep, 1 run above grade) are in.
An insulated shed will be attached to/behind the garage for the heating system.
In the house, there is currently an oil fired boiler and baseboard type radiators.
The garage is approx 40' behind the house.
What to do?
I've had many a great plans, and each one has gone for a ...
Instead of rehashing all the ideas, here's the directions and if anybody can advise on the different issues, I would much appreciate it.
1 - insulation and vapour barrier: I feel this is the best insulation product in my area = Insta Panels
I'll be going with the steel sided under the floor, fiberglass on the foundation walls. I only intend to install the panels horizontally on the foundation walls (or 20" deep) which mean about 12" will be exposed above the floor and 2" will be lower than the concrete effectively meeting the insulation panels under the floor. The slab would be completely insulated.
However, I'm a little unsure this is right? Do I need to insulate the entire frost wall? Do I add a vapour barrier between the frost wall and the insulation? I'm told to use "Air Bloc 21" only.
Vapour barrier is a given under the floor (although the heating company I "was" going to use said it's not needed!!). But where do I tuck the ends of the vapour barrier? up and under the insulation on the walls, or down and away?
2- Heat supply = I'd wanted to save $$ by trying to heat both the house and shop off the same system. That's not working because the house radiant won't match the shop radiant. And, the insulated pex is $$$.
So now I'm looking at heating the shop on it's own.
There are many great thread on GJ, but none seem to fit my situation?
Electricity is ridiculously expensive here, and propane is worse. Oil is OK, but it take a lot of space and the tank can be expensive.
I like the idea and simplicity of an on demand water heater, but am afraid of the monthly bill. I haven't figured out my heat load or loss yet, and am unsure how to do it right. So far, I don't trust ANY of the contractors in my area, as they contradict each other and what I have learned on GJ.
Boilers can be found pretty cheap on CL or Kijiji. Since I already have oil to the house, do I go boiler and oil? Do I chance an electric on demand system? The simplicity of this system was described in a post on GJ... I don't know much about heating water, but it seems I know as much as some of the contractors here
What to do?
