joseywales
it only jinxes you and leads to more work!
I went a bit nuts lately, jumping waste deep in M12, when I was already neck deep in Ryobi 18V. Then the Amazon Prime Day hit and I grabbed a set of 1/4" Sunex impact sockets, among other toys.
Today, it will be 100+ degrees and stay there for a couple days. Two days ago my 10 year old pool pump went and today my 10 month old HVAC is leaking internally
On the upside, my wife has been mum, as I used the M12 and Ryobi tools to keep the pool wet and the HVAC...dry
Well, the HVAC isn't solved just yet. I'm hesitant to go any further, since it's under warranty, but I suspect it might be debris in the line, which is not covered. To find out though, I might have to star removing things. The usual condensate lines appear to be clear. My P trap is clear in color and although there is water and it's not clogged, there is also remnants of yellow insulation.
The water is dripping from the bottom of the vent pipe, where it connects to the top of the HVAC. I might just post this on the HVAC section if I can't get it figured.
