Was this ratchet wire brushed?
chadster1
Terrell, Texas
I never doubt the Garage Journal's knowledge.:bowdown: I just don't understand why anyone would take so much time into doing something like this. Wouldn't a broken lock be something that would be warrant-able?
Yes it is. We will never know why someone decided to weld that hole in.
Bart Simpson
That ratchet is a real POS and I would of been disappointed if all the defects were not disclosed.
I don't understand why anyone would think Snap On should warranty it and give you a new one if the head is floppy because usually all you have to do is tighten the screw and your good to go, the old washer can also be bent a little to provide the necessary friction.
But since you said the washer is missing , the kit you ordered should take care of it.
With the old ones where it was just a pin ,sure there your stuck once there really worn out ,but these ,no problem.
There is no copper layer ,it bare metal , then nickel, then chrome.
The nickel will have a yellowish tint.
It looks like someone sanded all the chrome off it as the darker areas are the bare metal.
It should have a lock button and the locking pin to engage the grooves on the flex head.
That is bizarre that there is no lock button, it does look like the hole for it was filled in with something.
The hole in the top of the handle just below the flex joint is for the locking pin .
Someone has obviously removed the locking assembly from this ratchet.
Why they would do that ...who knows ...but yes it would of been covered under warranty.
Altering the tool generally voids the warranty.
mrshaun
Killeen - Fort Hood
why would they do that? big waste of money. they know when they are making improvements and monitor stock levels to pull the trigger on the new release. if they have tons of stock on something and want it gone fast, they offer a fire sale and push it out the door....
