Wasps !!!
sublime68charger
SW Wisconsin
They will go down if you spray them with wd 40.
Give the nest a good soaking as well,
As far as traps put out a dish with some mt dew and add some dish soap, I think is what I was told.
Good luck
dowmace
KCMO
This guy
6a00e550fd7dc288330120a60f3418970c-pi
filled with dawn dish soap. The soap eats the exoskeleton off of them so they go down from the weight of the soap and die from suffocation. Or so I'm told, all I know is it helped me get rid of thousands of the bastards without a single sting.
T_R
Maine
I just had a huge nest the size of a basketball on the eave. I was just going to leave it and knock it down when it got cold and they were done for the year. But the little bastards stung me 4 times while I was trying mow, so it had to go.
First night after dark with a flashlight, unloaded a whole can of spectracide wasp killer on the nest from 20 feet back.
Noon the next day, piles of dead and dying hornets on the ground under the nest, but some still flying.
Just before dark unloaded a second can of spectracide wasp killer on the nest from closer distance and into the entry hole.
3rd day afternoon, it was raining. Piles of dead hornets larger, no movement, none flying. Knocked the nest down. Nest fell apart. Nothing came out. The larva inside were still moving. Threw the remains in the woods wriggling larva and all, it was too wet to burn it.
Today no signs of returning hornets.
I saw video of a guy destroying a nest with a pressure washer. It was mush and off his house and they were dead in seconds.
ADSR
Also, If it's a nest, I use this foam spray and foam up the entrance to their nest so if they want to go in or out, they touch the foam and die.
BD1
north side
A hornet nest is tough . You spray the opening but the dam larva nest is higher up inside. BASTARDS ! I used the RAID WASP killer and it did well. Sprayed at night and in the AM took the big rosebud out and torched the nest. Boy that sucker went up quick !! SUCCESS ! :rocker:
robalmal
Triabunna Tasmania Australia
We have had two lots of wasps over the years. If you can watch and observe them, esp. at dusk, they will lead you to their nest. Usually underground.
I poured about 2 litres of petrol down the hole and then sealed. No need to ignite the petrol although I can well imagine some of the people that frequent this forum doing just that. :D
58Yeoman
Central IL
A couple weeks ago, I was putting vents in the sides of one of our sheds. When I climbed down the ladder, one nailed me twice in one finger. I found their nest nearby, and they all paid the ultimate price.
Milton Shaw
Make sure you are not allergic to wasps before you start trying to get rid of them. Here in Knoxville we had a fatality this year from someone who didn't know he was allergic. Also another fatality from a guy who got stung and could not get to his epi-pen in time and died half way into his truck. I found out I was allergic to one kind of wasp about three years ago and have been taking allergy shots for them ever since. My wife now sprays the wasp nests after I find them.
HeadsUp
Central CT
Didn't used to be allergic to wasp stings. A few years ago I was stung a couple dozen times. Now when I get stung it's a trip to the doctor. Doc says I'll need an Epipen if I keep getting stung. Told him I don't go looking for them but I like to be outside with my boys.
Always keep a couple cans of hornet/wasp spray on hand. I've heard that wasps return to their nest at dust. Just as a precaution that's when I take care of them.
vintovka
Hate wasps (the insect kind) The mud daubers cost a friend big $$$ when they built nests in all his rifle barrels he had stored in the rafters of the garage. The mud plug rusted a ring in each bore ruining it.
03protege
Louisiana
This guy
Soap eats the exoskeleton off of them? :eyecrazy:
joseph.a.owens.9
I would never store a gun in a garage unless it was in a safe of some sort. A gun is like gold they will never lose value if you keep them nice.
dowmace
KCMO
According to the Internet, and you cant put anything on the Internet that isn't true.
I know they go down and die, I've been told the ingredient that cuts through grease is what gets their exoskeleton. How true it is i don't know.
Sent from my SM-N910P using Tapatalk
LS6 Tommy
Northern NJ
This guy
The soap is what suffocates them. They breathe through their exoskeleton...
Tommy
MoonRise
This guy
No, the soap does not "eat the exoskeleton". If it does, then the soap you are using is waaaay stronger soap than what I have!
However, the soap does lower the surface tension of the water and thus the water can 'flow' over the insects' teeny-tiny breathing 'holes' along their exoskeleton and thus they 'drown' or suffocate.
https://en.wikipedia.org/wiki/Respiratory_system_of_insects
It works, but I usually prefer insta-death via 20'+ away with Wasp-and-Hornet killer in a can. Insta-death and a residual effect on any in the nest who try to leave and touch the liquid or any who try to return and touch the liquid.
Although the foamy version is also quite effective, especially on a ground nest of yellow jackets.
Hit the nest at night to avoid most of their activity and don't spook or disturb the 'guards' (no joke there) until your chemical death assault is fully under way and those nest entrance guards are the first casualties, although there are often a few 'stragglers' who didn't return to the nest for the night (out partying or missed the last 'bus' back home before dark, or such :D ). Hence the benefit (for us) and detriment (to them) of the residual effect of the commercial wasp sprays on any stragglers who try to return later or attempted escapees who try to leave after your direct spray assault has stopped.
ADSR
please youtube this wasp adventure and post it here.
Falcon67
Merkel, TX
Yard Guard is my weapon of choice. I get right in there amongst 'em. Early morning and late evening are good hunting times. Bugs mostly on the nest around then.
Overhaulin63
Akron, Ohio
Grandma would take some powder poison and put it in an old shop vac and **** them all up and then let the shop vac run a little longer...done! She lived to be 91; God Bless her.
Zombifyd925
Saratoga County, NY
I use an empty water bottle. Cut a slit about an inch long sideways and try to push the bottom in so the bees would have.to climb up and in. Then put some sweet liquid in it and tie a string to it and hang it. It's very effective!
kf4zht
Calhoun, GA
38 special - regular primer, ~2gn of fast powder, cardboard wad, grits, another wad and a good roll crimp. You can cut the wads with a sharpened case and a hammer.
On the bigger side 12ga with walnut tumbling media and about 10gb of red dot. You will have unburned powder but it's enough to disintegrate them. I use ***** wads but a gas seal works better as the weight increases.
JRC3
Southwestern OH
I've cleaned residential windows for years and in the beginning I would hit wasps with my squirt bottle of soapy water hoping if they were wet, they couldn't fly until I was long gone a few minutes later. I quickly realized it did that very thing but it also killed them. They would drop away and die or they'd hang on the nest and die there. Good thing to learn when you job keeps hanging off a ladder at 2-3 stories. Other good thing to learn is to act like a tree and they will go away. Running and/or swatting will get you stung.
Seriously, a quart of water with a table spoon of Dawn is all you need. I use a squeeze type bottle (basicall just a home drilled in a lid.. Been doing it for nearly 20 years and probably killed a few thousand.
94EG8
Chlorinated brake clean works better than anything else I've seen.
Dberglind
Over the last week I have watched the continued Wussification of America. I run a landscape crew, and while on a large commercial job we came across 7 or 8 yellowjacket ground nests.
No one wants to get stung, and if you are allergic, that is a whole different deal.
But what happened to the days when a guy got stung, he said "F&$* that hurt", and moved on with his work day?
These kids I have working with me these days gotta call the boss and let him know they were stung, call their mommy, rub it with ice cubes, put ointment on it... they are pretty much worthless the rest of the day. :dunno:
kenners
SE Wa State
I thought wasps build the nests, hornets live under ground ? I've used wasp/hornet spray on wasps. At around $ 5.00 ish for two cans it can add up over time. I've found filling my 3 gallon backpack sprayer with about one squirt of Dawn dish soap per gallon of water works on hornets. I've got hornets between the sheet metal siding on my shed and the insulation. Sure would like to be able to pour soap solution down their hole !
kirkkw
Leander (Austin) Tx
I couldn't have resisted. :bowdown:
chillrich
I got the last two traps at Canuck Tire South Kamloops today. $17.99 for a plastic bottle solution that doesn't work and $7.99 for the one shown here that captured about 30-40 wasps in 3 hrs.
LS6 Tommy
Northern NJ
Apparently a lot of people are frightened about an occasional insect that wanders into their garage. If that's your scenario, let 'em be. They just want out. If you have nests in potentially hazardous locations or swarms, blast 'em. In my 50 years of walking this planet I have yet to find any insect other than a Yellowjacket or mosquito that was intent on harming me just because I was there...
Tommy
