rburke65
JPrato....how do you double seal you ver head doors? Thanks.
How much does electric cost in your area ?
here's a crazy question ........... instead of the waste oil thing. couldn't i just install a normal 'house style' hvac system? yea it would be electric. but it definitely is virtually maintenance free and I wouldn't have to mess w oil. does anyone with a 2000-3000sq ft pole barn garage have one of these?
it would of course be heat AND ac. my plan is to insulate my 40x60 shop and keep the heat at 48-50 deg or so when im not inside of it in winter. but i have water in the bldg and other things that cant really be cold. so 48-50deg should be fine when im not in there. im assuming a decent 'house-style' hvac system would be fine? Air handler, outside unit, little vents on ceiling, etc etc.
So if you were leaving it on full time in the winter, you'd be burning something like 700 gallons of oil per month? 1 gallon per hour x 24 hours x 30 days =720. Could your shop support that much oil? Depending on how long the winter season lasts, that's like 2,000 oil changes. Does your shop do that many oil changes per year?
1 gallon of waste oil has 140,000+ BTU/gallon.
41 KWH = 140,000 BTU
41 X $ 6.57 = $ 269.37
You would have to spend $ 269.37 in electricity to get the same heat as 1 gallon waste oil you generate for free.
Uh, no
it's $.065 per kw/h
so 41kw/h x .065 (per kw/h) = $2.67
If one gallon of used oil made the equivalent of $269 in electricity, everyone would be burning oil
and the compressor is used for the waste oil heater. that uses electricity to run and of course general wear & tear on your compressor. and SOUND from compressor.
and of course the cleaning/maintenance.etc etc etc .... plus an HVAC sys would have AC too!
I was not aware they had so many additional issues regarding maintenance, filters, air compressors, metering pumps, chimney maintenance, rebuild kits, etc plus just the significant cost of the unit itself.
6.577 cents/kWh
edit: I think you meant $0.06577 but not sure.
Thats a bill I'd like to see. Take your TOTAL bill, and divide it by the TOTAL Kw consumed, and lets see what you are REALLY paying. This will take into account the fixed fees, taxes, etc., and it truly representative of what you are paying.
My house for the month of September had a bill of $122.82 and a consumption of 875 kWh (total electric) and that works out to $0.1403 per kWh.
My shop (separate meter) had a bill of $34.10 and a kWh consumption of 185 giving a total cost per kWh of $0.1843 per kWh. Its higher because the fixed cost is the same as the house, but with lower consumption, the fixed cost is a larger part of the bill.
Charles
