BabaGanoosh
- Joined
- May 28, 2014
- Messages
- 67
Water absorbs in worst spots in 50 minutes. Does this pass for epoxy application? Thanks.
That or bondo. Dap actually makes a good concrete filler for the perimeter as well.
Dap is good for the perimeter as there is no traffic.
If it's only one thin crack down the middle, bondo.
Again our preference is a real epoxy filler/sealer.
Thanks man,
yeah its ike really thin (see the attached)
now when you say Bondo, you mean car filler?
Thanks again and sorry for the hijack
Yes. That's the only Bondo body filler I know. It's not meant to fill any thicker than 1/8" on autobody.
I lay primer tomorrow and have three more questions. 1) can I use gorilla tape instead of doing a scribe line under the garage door? Has anyone seen that work? 2) Is there some reason why I should paint the walls before I epoxy the floor? Can't I just paint the walls later?, 3) when I "cut in" the primer I do that first, right? And then I do the body of the floor with the squeegee and roller? It seems if I don't cut in first I will be walking across the epoxy. Thanks for enduring all the newbie questions (now if I could just figure out how to open that can of paint). ((Joking)).
Thanks. No primer today. I cut a scribe line, painted walls and now have to vacuum the floor again. Try tomorrow. I ABSOLUTELY should have painted walls and cut scribe before grinding floor. Sheesh. Slow go when you dont know.
So how did it go? I'm curious why people suggest painting walls before applying epoxy? I planned to do it the other way around, but I'm adding baseboard trim and didn't want to be power washing right against it.
usually when decorating; you work from top to bottom; ceiling, walls, floor.
I suppose thats to stop drips and mess etc.
I'm painting 6" of the wall to floor area, after I epoxy the floor, sealing the perimer with the epoxy; hope thats not gonna cause me any probs
Meh, I figure that's what drop cloths are for. I mean the floors are already done when you repaint a room in your house, and in many cases those floors are much more valuable and less stain resistant than any garage floor.
I didn't want to pressure wash concrete adjacent to new baseboard trim. In a garage I think if you have the opportunity to get the floor down first and then do the finish work on the walls you can save yourself a lot of masking trouble.
