water concrete floor??
mnpeterg
new shed build (30x16). monolithic slab 12 inch footer, 6 inch floor. concrete was poured about 8 or 9 weeks ago. Walls and roof have been up for a few weeks. Today I noticed a wet spot on the on the concrete floor (see attached pictures). (about 18 inches from the edge of the footer. We have had a decent amount of rain over the past several days. It is not from the roof, I’m thinking it’s from the under..??
-I did put a very thick (15mil) vapor barrier under the pour.-
Thoughts?
I do plan to use some self leveling concrete in a few weeks to level some areas. Possibly put a bit over that area.. any ideas...
Shiftless
East Bay SFO
Here are some pertinent questions. :
Is that slab well above the soil on all 4 sides with soil sloping away from the building? Does your building have gutters and downspouts with drain pipe carrying the rainwater well away from the building? I assume your heavy plastic was not seamless. Is the wet spot near a seam or overlap? Did you bring the plastic membrane up and over the sides of the slab?
Can you be absolutely completely positive that the roof doesn’t have a small leak?
BTW, many here on GJ will be of the opinion that the level of finish of that pour is less than first class. 😎
mnpeterg
The slab is a few inches above the soil, the concrete blocks that sit on the footer have also been drylocked.
No gutters.
The moisture barrier did have a seam, and I use the ‘special tape’ from the manufacture for under slab moisture barrier.
Could the water under the slab really be penetrating after 2 months a 6 inch slab with a decent barrier?
I’m as certain as I can be that its not from above.
Would putting a thin coat of concrete over it help?
Shiftless
East Bay SFO
I’m no expert. I did a thin overlay on a crappy looking 8x8 slab that used to have a hot tub sitting on it for 20 years. The slab was not finished too carefully because it was poured for the sole purpose of supporting a huge tub of hot water.
After the kids left home, the spa started leaking and we didn’t use it much. I cut it up and hauled it to the dump.
Anyway, the slab looked bad with irregular finish and stains. I DIY’ed a thin overlay and a broom finish. It held up well. It’s about 5 years old.
But it gets only occasional foot traffic and no vehicles at all not even a lawn mower.
I would fear that for a working garage, any thin overlay might crack and separate and or flake off leaving you a big mess.
Uncle murph
Harford county
Thoughts?
Looks more like oil to me,that being said,anything that’s at a temperature below the dew point particularly in humid weather is going to get wet and vapor barrier won’t change a thing.
