Water Filtration
ckucia
West Virginia
I'm no expert, but as with most things, the answer is, it depends.
What are you trying to filter out? Grit? Iron? Minerals? Bacteria? Chemicals?
From what I've gathered going down this road, the best approach is to use a series of progressively smaller filters to trap particulates, then you can use a carbon filter on the clean water, and then can deal with bacteria.
You may not need all of it.
In my case, and I just got the filter inserts yesterday, I'm starting with a 50 micron stainless steel screen filter to trap any big particle, then a 5 micron washable 10x4.5, then a 1 micron 2.5x20, then an activated carbon 2.5x20 and finally through a UV light 2.5x20.
Most of the above sizes are dictated by what the PO left lying around the garage.
73fxe
SW. Michigan
I use a filter like You have pictured, but Mine is only 1 stage. It's in front of the water softener. I change it every 2 months and it works great.
Makoto
Houston, Tx
We have a whole house filtration system. Rainsoft, i think. we really like it a lot but it was pricey.
J
jjgrappler
I do plan to have the water tested, I have minerals in the water and I want to filter sediment as well. I do notice sometimes if I tax the well too much I can **** up sediment and I want to keep that from my appliances. Thank you guys so far for the responses.
BucksCtyMike
If you are sucking up sediment, you definitely need whole house filter like you linked in post one. Sediment will reek havoc on every fixture. You might also want to investigate why you are sucking sediment. Several reason why potentially, but it’s not ideal. Hopefully it’s minor.
Once you do that, you’ll need a test to check PH and hardness, as filter won’t fix that.
We use the rainsoft system mentioned above to to correct PH and hardness.
J
jjgrappler
I **** up the sediment when we use two appliances at once and the pressure drops too low.
kwschumm
Olympia, WA
We have an EWS Spectrum filter. Good for 10 years at least. One of the best, if not the best filters going.
rharman
SoCal
We're on city water but have the Big Blue whole house filter. Only single stage but with well water, I'd assume 2 or 3 stage would be more prevalent.
Pentek Big Blue is a nice product.
TractorJeff
Elkhorn, WI
I have a whole house filter like AP514, only mine needs changing approximately once a month. It captures some of the bacterial iron and occasional sand before the water softener. Under the kitchen sink is a carbon filter that gets changed once a month also.
I doubt you have a "dug" well as they are usually less than 30 feet in depth. Water at that level or less is typically considered ground water (filtered) which due to typical pollution is no longer considered sanitary. Nitrites and Ecoli are 2 of the biggest issues.
That said I grew up around a few houses that had Natural Springs for there supply.
As posted earlier, need to get water tested.
lakeroadster
Central Colorado
We have a dual filter set-up with a 20 micron and a 5 micron.
  • Cold water only uses the 20 as a single stage.
  • Tankless hot water uses the 20 and the 5 as a dual stage.
All we have is some iron, not that much. I change the 20 stage once a month and the 5 every other month.
Seems to work pretty good. We buy filters from Home Depot and Amazon.
I like the clear polycarbonate housing.. so you can see when the filter starts getting overwhelmed.
larry4406
Northern Virginia
lakeroadster - I have the same filter as you and like the clear bowl. My home Depot used to have their HDX filter brand that fit it but have now discontinued it. I will have to check Amazon
