Fix one problem and another pops up. I closed and opened the valve while fixing the leaking bleeder and now the shaft of the valve stem is leaking a bit. Are these serviceable ?
As for that drain cap, some are not removalable ! Just saying.
The drip on valve stem is from valve packing. Some have a packing gland under that outside nut. If you loosen nut and slide up you may see valve packing material. You can roll Teflon tape like a Twizzler and lay inside. Or easier to hold nut up and make a few wraps around stem and thread. Then snug nut, doesn't need to be tight.
