RHD 4 LIFE
Has anyone on here ever ran a system similar to this? I'm thinking of running off the NG water heater in the house, out to a A/C coil with a fan and inline pump on a timer in a loop fashion.
So hot water out side of heater to ball valve with drain, on to pump with timer, out to coil with pusher fan on same timer, return line to ball valve with drain, into cold inlet on water heater!
Drains ar so I can empty it in the nicer weather so i dont get stagnent water.
I was thinking I can run one hour on, two hours off sort of thing?!
I could later install a thermostat as well if needed, and my garage never really gets below freezing anyway.
Any input is welcome.
Thanks in advance
John
Thanks in advance
John
