Water heater TPR angling allowed?
ching0n
I need to route the discharge piping for the TPR on a water heater and angling the valve itself would save me some hassle. Is there angling allowed by rotating the valve or must all angling happen after the valve?
Thank you,
kaymccampbell
Upstate New York
IME, TPs can go flat, like horizontal, but never up, or be trapped. You never want standing water in the line. They want minimum bends, no threaded bottom end, terminating a couple fingers off the floor.
C
ching0n
sweet; that should simplify things some.
Also, anyone ever mess w/these setups? They're polypropylene but I find no way to elbow them so I'll probably just go w/pex or iron instead:
PCustoms
VT
Yep, it's a simple, cheap pipe.
What are you trying to do? IIRC you have to have the tpr discharge open to atmosphere with X inches of the valve.
I may be wrong.
nadogail
Coronado, CA
Temperature and Pressure relief valve should not be restricted, as short as practical, and have very few bends. This is coming from an Electrician, a Plumber can be more specific.
C
ching0n
I may be wrong.
Trying to pipe it to discharge w/an airgap into a wye shared by the washing machine drain.
Innovate1
T&P valves need to drain to a location so it is visible that they are leaking. not sure an air gap is sufficient "visible location"
In my shop the water heater is on an elevated platform with the furnace and both drain to an elevated trap with an air gap. The inspector for the plumbing was specific about several details of the installation but had no issue with the T&P drain so that's fine here. Might vary in other locations. I put a 2 x 3 PVC coupler on the 2" trap to catch more of the spray from the pipe if it ever vents.
