Water hydrant locations?
mcbane
California
If you plan larger than garden hose sized hydrants you should call your local fire department. They have rules on placement (minimum distance from structures, etc) and will specify what diameter and thread type you need. My understanding is that 2-1/2" NST works in most of the US but there are a few oddball locations where your local fire dept wouldnt be able to use that size and type of thread.
Stuart in MN
Minneapolis
Still working on running water to my house at the shop.
Do you mean running water from your house to the shop? Are you talking about locating a hose bibb on the exterior of the building, or putting one inside? If it's inside I'd think you will need some sort of drain, which is a whole other issue.
wssix99
Chicago, IL
Put enough faucets so you can reach all areas of your property with the hose length you desire, without crossing driveways, enterances, or sidewalks.
This is the error we made on our house. We can get everywhere with a hose, but if we want to leave a sprinkler up on a timer, etc., we need to leave a hose across a porch in some circumstances. We wish we would have put in one extra...
brownbagg
god hates me when it comes to dragging hoses, he has a sick sense of humor, he will find every twig, blade of grass to kink a hose
510ebl
Southern New Jersey
I too wish we had more than the two at our house. I also wish they were mounted high enough that I didn’t have to bend way over to turn them on. The hose reel gets in the way as they are.
Each side of the house should have one, all frost free and the supply should be “oversized”. As in at least 3/4” all the way from the shut off for the house to the bib.
We are raining ash right now, so a local forest fire is on my mind. You can do a lot to protect your home with a residential hose bib if you have enough flow.
larry_g
oregon
Are you on a well or city water. I'm on a well and have hydrants at the well house and a whole separate water system for watering outdoors so no hoses connect to the two spigots on the house. The outdoor system has an 1,25" line that runs about and has some 3/4" lines that Tee off of it to the different gardens and outbuildings. I have a 1" line that feeds the house. I also have a few shutoff valves in the system to shut off lines in the winter or if there is a problem on that line. If your building and the property is still tore up then it's perty easy to bury some PVC out to the places water is needed.
lg
no neat sig line
Leaflessshadetree
Don't ask.
I have one at the sink inside my garage. I've occasionally wanted one outside near the overhead doors and one on the side which is also the driveway front of another shed. I could put a yard hydrant in at that corner of the building and minimize the chance of freezing.
But honestly I would only use it once or wice a year,
