cavalry
I consider my compressed air setup pretty decent but suddenly am having issues. Any large consumer is releasing water vapor at rate that is unacceptable. This setup has been in service for 10+ years so I am typically fluent in its abilities and fully understand that hot air holds water vapor which is undesirable.
Intake for the compressor is in the shop which is kept at 50% humidity year round, I have not had issues in the winter nor have I had issues in previous humid summers.
Compressed air leaves the compressor and before going to the 80 gallon reservoir goes through an after cooler. Auto tank drain is working correctly, there is no liquid water in the tank. I have a IR fa75ig 1 micron filter before my refrigerated air dryer, and another fa75ig .01 micron filter after the dryer, both of which are dry and indicating good filter. The dryer would certainly take care of the moisture issues but it is expensive to run so I operate only for critical applications, I run a bypass on the dryer when not in use so the air is still filtered but not going through the dryer. Like I mentioned, I have never had moisture problems before like this so I am not sure what has changed other than the weather which should not be a factor.
Any ideas?
Any ideas?
