scrapmetal57
Anyone ever run into this issue?
I installed an underground gas PE line to my garage but hit it with a trencher when I was digging for my french drain I went a little too deep. Before I spliced in a new section I think some water go in the line.
When my garage furnace is running the pressure fluctuates from 0.1 to 2.5 inH2O, static pressure is 6.0 inH20. Its an old furnace but it is definitely from the supply line into the garage. I replaced the thermocouple, gas valve, and it didn't fix anything.
My theory is that water got in the gas line and is causing a constriction so when gas flows the pressure decreases. I have a hose that I am going to try to run through the line and see if anything comes out with my shop vac.
I can post a video of the furnace in operation once I get 5 posts.
