fireball05
Hello all,
Just recently found this forum and have been reading around - I have a detached 2 car garage behind my house that the previous owner had severely neglected. I have finally begun to clear it out and make plans for try and emulate some of your dream garages I've seen here!
It is a simple 24x24 garage, poured concrete floors (must be 30+ yrs old). Walls are 3 stacked concrete blocks and then the bare framing with exterior covered with plywood only. Now that it is cleaned out I had plans to prep the floor for one of the DIY epoxy coatings I've read about here. Problem is that when it rains I seem to have some serious moisture seeping either up from the floors or through the block perimeter.
Does anyone know what steps I could take to eliminate this water from getting in? The block perimeter has never been sealed or painted, and I'm sure the concrete floor is bare as well (save for lots of dirt and oil spills!) I'm worried that with this amount of moisture seeping through, I'll have no luck at all with the epoxy coating.
Any advice would be greatly appreciated - please keep a tight budget in mind when giving any suggestions.
Thanks in advance.
Thanks in advance.
