Water leak in basement
outwestjake
Pennsylvania
Hey everyone, so had a bit of an accident. I live in a raised rancher style home with the front door split between the two floors. When doing my annual bug spray, I bumped a little too hard against the pressure gauge at the well water pressure tank and it snapped off. In this moment water was gushing out, it was hitting the subfloor ceiling of the closet. I managed to put a roll of paper towels over it to prevent it from shooting straight up and quickly ran to the breaker panel to kill power to the well pump. Immediately after, I emptied my shop vac and started sucking up as much water as I could.
I have a 16gallon shop vac, and I probably got it about half way full. All in all, if I had to estimate, this was all at most in the amount of 1 minute. The water was gushing out of a 1/4" NPT ****** that had snapped at the threads. My well pump runs at 8gpm, however, the pressure tanks holds 32 gallons... This all occurred in the closet under the steps for the front door. I could see a good bit of water flowed out into the garage through the wall.
I've had a dehumidifier running in the closet since then. My biggest fear now is the damage done to the carpet in the basement. I'm guessing 25-30 gallons of water could have spread from the closet, maybe 10 gallons went into the garage? I'm concerned about mold growth. Would anyone recommend pulling up the carpet in that area to check the padding? I couldn't feel any dampness, but I'm sure some water seeped through and the padding is probably blocking it from soaking up. Just looking for some suggestions or a sanity check. I'm about ready to empty out the basement and just tear up all the carpet.
Ole Slewfoot
Freedom, CA
Dust a few.spots with baking soda, if its damp it will stick.
Go at the carpet with the shop vac, it socks nust as hard as the carpet cleaner extractors.
rlitman
Long Island
One dehumidifier isn't going to cut it. You want at least two or three running 24x7 until the space is BONE dry (give it a week). At least your water was clean. I needed remediators to help with my flood when a cast iron waste line broke.
P0234
NoVA
Definitely lift the carpets up. Its super easy to get them back down again, worry about that later. As mentioned, have every fan you have going down there and keep humidity under 60% as mold grows above that.
PelicanPines
Do this... don't leave the carpet in place. Even if it magically dries out... moisture will be held to the floor under the carpet and the amount of mold would be shocking.
O
outwestjake
Pennsylvania
Yea I think I'm going to pull the carpet back as far as it is wet on the padding. Atleast so it can breathe. And then decide what to do next. Until I do that i don't really know how much is soaked. We've been wanting to get rid of the carpet anyways, so maybe this is a good excuse
