pwhittle
Our home is almost 30 years old. We have been here 6 years.
In the last 12 months we have an intermittent screaming from the water pipes. It will start randomly and continue for 1-3 minutes. The noise seems to be coming from all over one end of the house on the main and basement levels
I can feel it as a vibration on the hot water pipes to some of the faucets. No vibration on the cold pipes,
This happens when there is no water running, normally at night with no trigger, and sometimes right after a shower is taken.
If you open either hot or cold faucet, it stops until you shut it off when it starts again. It eventually stops by itself.
Most of the pipes are copper, with some Pex added 10-12 years ago when the basement was built out. During the build out, the traditional water heater was replaced with two instant on water heaters mounted on the outside of the house, with new hot lines fished back to the original location of the water heater for distribution to the house.
I have replaced the toilet fill mechanisms.
What should I try next?
Sent from my iPad using Tapatalk Pro
