Just installed 3/4 copper air lines in my shop. It comes out of my compressor, (2 stage, 175psi) and runs about 40' before the first drop. My mainline is sloped, and my drops come off of the top of the mainline pipe.
My main tool usages are blast cabinet, plasma cutter, and air tools, and I want to be able to paint occasionally eventually.
First, should I regulate the mainline, or just the individual drops? This could end up being costly, since I have about 4-5 drop locations I will use on a regular basis, with varying CFM requirements.
Second, should i install a water separator in the main, say about 30' from the compressor, or, use lower cfm models for the drops? Or do I need to do both?
Pros/cons of separators vs coalescing filters?
Lastly, what products do you guys recommend? I especially want my blast cabinet and plasma to be dry, but not sure how good is "good enough". When I get in to paint, I plan on using disposable point of use filters to really get the air clean and dry. Hopefully it won't be needed, just in case type thing.
