Water softener causing terrible buildup in drain pipe?
MatBirch
Filer, Idaho
Is this a common problem? It appears to be salt? It has totally crusted even the walls of the drain pipe in vertical sections, and has virtually closed shut two seperate traps in the line. This is over the course of only about 5 years. What do I need to adjust to prevent this? The softener only regenerates once a week, and there are only two water users in the house. Minimal use, really...
I tried a search, but most things lead to clogging of supply pipes and fixtures.
Crfdell
Cambridge Ontario Canada
Sounds. Ore like hardness. Salt is water soluble so it shouldn’t deposit.
Sample a piece and drop some acid on it like HCl if it bubbles likely not salt. Recommend a good pressure cleaning and inspection of your lines.
bob15
Northeasten, CT
Use PVC. Been using mine for 15+ years and I have going through an 1-1/2 PVC pipe (also a sump pump discharge pipe) with no issues.
glentre
Gloucester, Virginia
While not directly related to your problem, many water softeners have two recycle settings. One recycle is set on a timer as yours seems to be and the other setting works on amount of gallons of water used. With only two people in the house, setting the recycle on amount of water used would be a more economical approach and also cut down on your scaling problem.
I agree with the post above. During recharging, the salt is mixed with a lot of water and should not cause any deposits in your piping at all. Are you sure your softener is actually working properly?
Glen
MatBirch
Filer, Idaho
Plumbing is all PVC. House was built in 2016. I'm pretty sure the softener is about the same age. I think the next step is to get the softener company over to see what's going on.
MerlinsBeard
MD
This reminds me of no water urinals installed in an office building I was in a few years back. Sure seemed like a great water savings idea at first, until the deposits from urine blocked the drainage pipes. They have then switched to "low" water flushes.
