water systems for iron removal
moto367
Anyone have issues with iron in their well water? Are you using a system to remove it? What kind and how well do they work?
nafterclifen
Poconos, PA
When I bought my house in October 2013, I had the water tested. Iron was .73mg/L which was over the .3 mg/L DEP/EPA standard. Previous tests (in 2012) and follow up tests after 2013 reported lower levels of iron in the .1-.2 range. I can't explain why that is but the point is, conditions of a well can change.
There are two difference types of iron - ferrous (can't see) and ferric (can see). A water softener can remove ferrous iron via the ion exchange process. However, they cannot remove ferric iron. A separate filter, or a combination softener/filter, is needed to remove ferric iron. The filter media that is used to filter iron and other materials greatly varies so do your homework. Terrylove.com forums was a helpful source of info for me.
I ended up going with a Marlo CMP-25 combo unit. Although I probably did not NEED the media filter, I decided that it was worth the extra investment and piece of mind in case conditions changed in my water.
Garage Junkie
Cleveland, OH
Subscribing as I'm curious about the answers to this question. I have very high iron as well- if untreated, I have orange rusty water when water is left in the lines too long and rings in the toilets. I run a older water softener with iron fighter salt that takes care of most of it, but wondering what else may be out there.
