suzukiwarrior
i just put up a 30x40 with 3 doors 9+8 and every time it rains i get water running under the doors and the builder told me you will get water under them and i said no just fix it what can i do to try to fix it????
If your slab is flat at the doorway you will have to put down the glue down thresholds like Matt M is talking about and or get gutters.
I had the same problem and did the thresholds and that cured most all of the problem. Then I had gutters put on the house and that has (short of a hurricane or sideways rain) solved the problem.
I have the same problem, I have thought about doing this on my garage but my concern is in the winter when I bring my truck inside and all the snow melts off it. now I just use a squeegee and sweep it out the door. that would be a lot more difficult with those thresholds wouldn't it? how do you manage that problem?![]()
I live in Florida so I don't deal with snow. Water and dirt sweep right over the threshold. Not that much of a problem for me.
Tighten the doors up so they do not move (they are adjustable). Put a gutter up. Right now half the roof drains right in front of the doors. Put a weatherstrip around the doors and make sure you have a good bottom seal. Make sure your drive slopes away.
