watts = lumens
OldBarn
You can't do that. It depends on what type of lighting you are using. Every bulb is different.
alfredeneuman
Fullerton, CA
There's no set watts to lumens ratio
It all depends on how efficient the light source is.
LED for example has a much higher efficiency than incandescent.
A
akpolaris
Seward, Ak
Then how do I figure what I need for 32' X 32' shop with 16' ceiling? I understood I was looking for 100 lumens/ sq ft. Is that correct?
BillK
Beautiful Southern Maryland
ak,
If your shop is 32x32, that is 1024 sq ft. If you want 100 lumens per sq ft, you will need 102,400 lumens. Then you need to figure out what type of bulbs you are going to use and then you can figure out how many bulbs you need. I was looking at 6 tube T-8 fixtures the other day and I think they were around 18,000 lumens for each fixture. In your case you would divide 102,400 by 18,000 and get 5.68 so you would need 6 of those fixtures.
Does that help ?
BillK
Is 100 lumens/sf adequate for a shop?
I think it should be. My shop is 1800 sq ft with 14ft ceilings and it has 6 2-tube 8ft T-12 fixtures. The T-12 bulbs are around 5000 lumens each so I have about 60,000 lumens for 1800 sq ft .... about 33 lumens per sq ft. It is workable with some task lighting but definitely needs to be brighter. I am looking at replacing the T-12 fixtures with 6 tube 4ft t-8s, about 18000 lumens per fixture. That is going to almost double the light to 60 lumens per sq ft. and should be more than enough.
My walls are painted white which makes a big difference too.
laser3kw
northen IL
In my 30 x 40, I just installed 30 4ft t8 bulbs. The lights are above the 30 x 24 "work area" which has a 10ft ceiling. All walls and ceiling are painted white for best reflection. PLENTY of light
The lights are in 3rows- each row = 2, 8ft 4 bulb tandem fixtures and a 4ft 2 bulb fixture - 20ft total. == = == (bulb lay out per row)
CADPoint
WSW of **** City
http://www.visual-3d.com/tools/interior/Default.aspx?id=14783
Go play with your layout and see what your lights will give you.
Most people don't understand that most illumination presents itself
as a bubble of light and not as a complete spray of light.
One can note this on the bottom right of the web page of the light that you choose.
Below is what OSHA has set up as the minimum of lighting requirements for
various spaces.
https://www.osha.gov/pls/oshaweb/owadisp.show_document?p_table=STANDARDS&p_id=10630
A
akpolaris
Seward, Ak
This is a big help. The overhead lighting will be augmented with some specific task lights but this is a good start. thanks
LS6 Tommy
Northern NJ
I don't mess with lighting enough to know the ratings/formulas/conversions, but the guys at plantedtank.net pretty much go crazy over the various "how much light for *** gallons/** inches of water depth" discussions. The ones deemed to be the lighting geniuses say it's now about PAR ratings. Lumens is "old tech" and watt rating questions send them right off the edge...:lol_hitti
Tommy
