Rudyjr
I have an 18x8 foot Wayne Dalton 9000 series door installed on my detached garage that appears to be structurally failing. The door is approximately 11 years old and has been well maintained. I have lubed the hinges and rollers regularly as well as had the spring tension adjusted. Recently I had a spring fail and had them both replaced. Upon inspection it appears that inner metal skin is cracking and failing at all of the locations where it has had a sheet metal screw installed in it. It is most apparent where the hinges were installed. It should also be noted that on these doors there appears to be no reinforcement under the skin where the hinges install, only skin and foam. This door supposedly has a lifetime structural warranty. I contacted my buddy who installed and services this door and he said he has never seen this before, (he no longer sells Wayne Dalton doors though). He took pictures and said he will see what he can do. Anyone have any ideas or suggestions on how to handle this? Thanks, Jim
