I've got a pole barn garage and the man-door is a salavge door that came off an older building. I want to put weatherstripping on the outside the door and have not been able to locate the type that I want.
I'm looking for the old fashioned exterior weatherstrip that was made out of an aluminum strip with a gray fabric, sometimes rubberized fabric, embedded in it. The fabric is usually 3/4 of an inch and you tack the aluminum strip to the jamb. This type far better and lasts far longer that the stupid foam stuff they've got now. And you can run it flush with the exterior of your door even if the door isn't straight and true.
Does anybody know of a source or even what it is called? I haven't had any luck searching the net. Any help would be much appreciated.
