Weight limit for wall-mounted cabinets?
pgray007
Charlotte, NC area
I'm thinking of going with metal cabinets and storage lockers in my garage, probably from NewAge, and was considering mounting them to the walls. I have standard 2x4, 16" OC framing, and while I've never heard of problems with wall mounting cabinets, my spidey sense tingles a bit when I consider slapping a few hundred pounds of steel to the wall, and then loading it with another few hundred pounds of junk.
Should I be concerned at all? I'm considering wall mount mostly for aesthetic and easy cleanup reasons, so it's not imperative I wall mount and I can just out all the base cabinets and lockers on the floor if that's safer.
The lowly 2 x 4 (if made of Douglas Fir) will hold an incredible amount of weight.
I prefer 1/4" lag screws for fastening shelves to walls myself. Usually with a 1/4" fender washer under the head.
bob15
Northeasten, CT
That is the old fashion way.....:D
Try a TimberLok or a HeadLok screw in the future. Stronger than a lag bolt and no pre-drilling. http://www.fastenmaster.com/products.html
For the OP, I would go with a HeadLok screw
Jeff May
Fayetteville, PA
I had used wood kitchen cabinets. I thought I had them secured well.
As you can see, apparently not...
I had screws with washers into every stud behind them.
I was working in the shop and started hearing this creaking and cracking noise. I was watching as they slowly started just falling off the wall.
It wasn't the securing of the cabinets, it was the construction of the cabinets. The backs were still attached to the wall.
Let a fine ol mess of nails, screws and hardware....
Just make sure you get or make sturdy or heavy duty cabinets....
lakeroadster
Central Colorado
Bob Speaketh The Truth.. :thumbup:
I was at the local lumber yard, asked the guy "Got any good fasteners to attach cabinets to a wall" He says "they're right behind ya, they're Cabinet Screws". Who Knew :dunno:
krcoomer
Bluegrass region
I will second both of these options. Have used both in various construction projects since I read an article which was titled something like "not your father's lag bolt" several years ago. For hanging cabinets I believe I would tip toward the Headlok which has a little more surface area for the cabinet. Since you are using metal cabinets, if the head is too large for a mounting hole near a corner, the GRK would be the better choice.
Dobie
Warren County, Ohio
Yep, I install office furniture and we use the French cleat method. I attached one at the house and the wife has a couple hundred pounds of Christmas china in it plus the weight of the cabinet and it has not failed yet. They are Steelcase cabinets, but that picture of the cabinets falling and the back still attached makes me a little nervous!
Alchymist
Central PA
All good advice above. A lowly 1X2 screwed to the wall studs for the bottom of the cabinets to rest on adds a lot of strength to the installation as well as aiding in getting the cabinets up initially. Painted to match the wall, hardly noticeable.
Lsilkes
I had used wood kitchen cabinets. I thought I had them ....
I'm dealing with this right now in my garage. I noticed the cabinets (our old kitchen cabinets) pulling away from the wall.
I picked up some of the Sears Gladiator Metal cabinets and this thread comes at the perfect time since I need to get them mounted
Lorne
lakeroadster
Central Colorado
I guess the good news is you didn't have a vehicle parked beside the cabinets.
Curious, how much weight did you have in them?
Jeff May
Fayetteville, PA
Apparently a lot more than I realized.
Over the course of time one doesn't realize just how much "stuff" he can cram into cabinets.
Once I started cleaning up the mess I did in fact realize I had WAY to much weight in them.
I now have open shelving out of 3/4" plywood and plenty of cleats and support....
ToddW
In the snow
I put up 7 gladiator cabinets like this: https://www.amazon.com/dp/B008UQ0FAQ/?tag=atomicindus08-20
I put 4-6 lag bolts with huge washers depending if I hit studs or not. (the walls are OSB)
Under the cabinets I have 2x4s that allowed me to install them myself... ended up just leaving those there to mount little shelf onto so I can hold misc stuff. They're screwed in over and over with wood screws or drywallscrews whatever I could reach ;)
I don't think they're going anywhere, but this thread is proof I may be wrong!!!
EOC_Jason
Bentonville, AR
Those look identical to the Spax screws you can get at Home Depot... Same head, same thread... Same Dimensions... Probably made by the same company... lol
bczygan
DETROIT! Arsenal of Scrappers
THIS!!!
I had same thing happen with my new cheap kitchen cabinets. Had to reinforce them and rehang and watch what I put in them.
Bill
mray312
Use a french cleat secured to stud with GRK cabinet screw. It will support a ton of weight. :rocker:
