Weil McLain NG Conversion
foolishpride
Southwestern Ohio
Just bought a new scratch & dent Weil McLain LP Boiler. Got a great deal on it, less than half price of a new one. It's a LP unit, and I have to convert to NG. I see Weil McLain once offered a conversion kit, but can't find one online at all. I believe I just need to change nozzles in burners, and change spring in gas valve. The module indicates LP also, but I think it will work for NG also. Can this be done, and where to find new nozzles?
Thanks!
The Cobbler
if the manufacturer doesn't offer a conversion kit you're sort of on your own. you may invalidate any approvals it has on it .
natural gas orifices are larger than propane so they can be drilled out to the proper size. there are conversion charts found online . one such here https://ssl.ca/wp-content/themes/sinclair-supply/pdf/Gas-Orifice-Capacity-Chart.pdf you'll probably need a number sized drill .
as far as the spring in the gas valve, you may be able to trace that down by the manufacturer & number of the valve.
PoorUB
Fargo, ND
Thanks!
It might help to post a model number.
htmdude57
Hudson Valley, New York
Look up the manuafacturer's data on the gas valve. Some are adjustable, others use a manufacturer designed spring kit. If adjustable, you will need to have a "water column" manometer so you can adjust the regulator in the gas valve to the needed gas pressure for natural gas.
PoorUB
Fargo, ND
http://woe.wallingtonplumbingsupply.com/images/prod_docs/weil/CGA-SERIES_1&2.pdf
You can drill out the existing burner nozzles to 2 MM. It appears the gas valve is a Honeywell or white Rogers, you will need a NG regulator spring for that gas valve. Google the gas valve model and NG spring kit. The pilot will have a LPG orifice. You might be able to replace just the orifice in the pilot, or order a new assembly for NG.
Standing pilot or intermittent ignition?
F
foolishpride
Southwestern Ohio
Mine is a series 3. Not sure of differences. It's a Spark Ignited Pilot.
fitter30
Peace Valley,mo
Btu input and number of burners? If boiler is 75k 3 burners drill size for 25k. Need the correct drill size and a pin vice. Buy at least two or three bits. Drill buy hand twist with your fingers be gentle.
gmcgeo
Thanks!
You talking about the ultra series 3?
PoorUB
Fargo, ND
Thanks!
Can you post a picture of the data plate on the boiler? There may be some confusion here!
F
foolishpride
Southwestern Ohio
PoorUB
Fargo, ND
I see you got it covered.
I wonder why the replacement gas valve?
When I was doing HVAC, I would have drilled the nozzles for the burner, put a NG spring in the gas valve and a NG orifice in the pilot burner. The whole works would have set me back maybe $5.
