TT_Vert
Not sure if this is the appropriate place for this but I don't see any camera section. Basically I just got an RV and am replacing the zoom camera that sits at the top of the roof. It's a BNC camera but has no brand. It works fine in the AV port but zoomed too far in so i'm replacing it. The replacement qsee camera continually seems to scroll and look distorted with a changing frequency when moved (See video). The same thing happens w/ other bnc cables/cameras. I have a ton of new Analog Qsee QTH503B cameras. The odd thing is that when I try to use the AV (yellow coax) port it shows what you see in the video. I have tried different bnc cables, different power adapters and also different cameras. All produce the same issue. HOWEVER, if I plug it into the Component Y port it will show perfectly but only in black/white (when switching input of course). So I know the AV port is fine, the camera is fine (displays in component), the 12Vdc supply is good and the BNC cable is good. I am using an RCA to BNC adapter to do testing bypassing existing wiring but the problem persists. I also wired power right to camera to take the 50' of power cable in that bnc cable out of the equation. I have gone through the TV tos ee if there was some setting that could cause this and also defaulted the TV to factorty defaults just for the sake of argument. I know I can convert BNC to HDMI but I don't want to add more devices. I am going to try to plug it into another TV AV port today (if I have any TVS with one anymore)
Any help would be greatly appreciated.
Dave
Dave
