Between 485 & 705 SQ/FT Welcome......To Odd Acres
F
Finallygotit
Tucson, AZ
Letters add a nice touch Dan. The whole build turned out stellar my friend. Great job. Now get to work on projects IN the shop, we want to see more chips flying. ;)
It was official a long time ago Dan, you just put the finishing touch on a job well done.
Thanks gents!
Still have one more outdoor project on the shop that I'm starting now. I will be installing coach lights on either side of the garage door and another one beside the man door. The one by the man door will have a motion sensor on it. Going out there in the night is tricky. It gets ****** dark out here, even with the low voltage lights.
:beer:
zmotorsports
Northern Utah
Thanks gents!
:beer:
It's funny what just how much a little extra light changes the "feel" of things Dan. If I had been the original owner of our home I would have made certain to have included some more lighting along the side of the house garage but that would involve thinking ahead which the original owners of our home did absolutely none of.
Two years ago I added 3 large LED wallpacks to the side of my attached garage which tied in nicely to the floor lights and soffit lights that I installed on the shop when we built it. Now having the ability to turn on the wallpacks and seeing how much they light up so basically between the house and the shop there is full lighting it totally changed the feel of the back yard after dark. I don't turn the large wallpacks on very often so it was a rather large cost for low use, HOWEVER, when I do turn them on for either family get togethers or when removing snow I grin to myself each time I flip the switch. :D We had some friends stop by a couple of months ago and they arrived relatively late and it was also nice to just flip the switch on and have them back their coach into our back yard with plenty of light.
F
Finallygotit
Tucson, AZ
Small update
I mounted and wired the new coach lights on the outside of the shop. Adds a good amount of light and finishes off the building. At least I think so.
During the day
And at night
The light near the man door is connected to a motion sensor, that I added to the fixture, so I don't kill myself walking to and from the shop at night. (It gets ****** dark out here.) The two on either side of the door are controlled with a switch.
I used some of those fancy schmancy vintage look LED bulbs. 😁
More to come!
:beer:
F
Finallygotit
Tucson, AZ
Yesterday it was time for some quality shop time.
This past Christmas was the second time we put up the tree and we swore it would be the last if I didn't do something about the tree holder. Moving the tree around on the travertine tile floor through the grout lines is next to impossible. So I decided to adapt some wheels for the base.
Here's the base with the wheel I'm going to use.
Next, I pull out a rod of 1" polypropylene out of inventory and start making chips.
Next diameter for the head
Over to the saw to cut
Then face the back of the bushing, drill the hole for the caster and tap into the legs of the base.
And here we are with the finished product that moves along on our floors as well as carpeting. Very easily, I might add.
I am pleased with the outcome. :bounce:
Now we can easily decorate the tree and then move it to its location for the holiday.
:beer:
F
Finallygotit
Tucson, AZ
Dan,
Happy new year.
Nice work on the Xmas tree holder, any excuse for some shop work. 🤣🤣
Steve 🍻
Happy New Year to you too Steve. I hope all is well!
Lights and final outside looks great.
And when I look at your photos, I realise just how wet it is, and so different of course, where we live.
Thanks Rian! Funny, I often look at your posts and say to myself, "Does it ever stop raining over there?"
Dan the finish on the shop floor looks great.
Also nice job on the caster mounts for the tree base.
Thanks Mac!
The coach lights look very nice Dan.
Thanks Mike!
:beer:
F
Finallygotit
Tucson, AZ
Alrighty then.......next project. My friend asked me to swap out the wire rope in this boat winch with a nylon tow strap. This is what it looks like disassembled.
After I got it apart, I got the hub loaded into the mill. I needed to mill a 2" wide and 1/8" slot about 1/2" deep to accommodate the strap.
Slot done and chamferred.
Now to keep the strap from coming out of the slot, I decided to use three set screws to pinch the strap in the slot. So, turn the hub 90° and spot face for 10-32 set screws.
And done
And here are the holes drilled and tapped.
And here it is all together again. I was able to get just a little over eight feet of strap in there. The owner told me to do the best I can. I hope this works for him.
:beer:
madison069
Monroeville, PA
Garage looks good! Your night photo reminded me that I wanted to get portable stands for the table saw and miter saw.
As for the boat winch, I'd say that's a damn good job of putting that nylon ******** there in place of the wire rope! Now he can replace the nylon strap every 2-3 years as precaution easily with your set screw setup! I can 100% understand why he wanted the strap instead of the wire rope too, stupid wire rope can cause a lot of pain if you're not careful and it starts to splinter apart!
DeeDubz
Socal
:beer:
I've got the same base for my christmas tree. I might try and do that upgrade.
F
Finallygotit
Tucson, AZ
Thanks for the kind words Madison! From what I understand, the owner of the winch had had enough of the wire rope creating a bird's nest when he unwound it. I forgot about the splintering you mentioned. I HATE that.
Nice job Dan. Having machining capabilities in a shop are invaluable for projects like that, and fun to boot.
Thanks Mike! I enjoy the challenge to figure out how to hold and machine a work piece. I also enjoy figuring how to get "here" from "there".
My wife can now easily move that 9 foot tree around.
:beer:
82355
Bradish Nebraska
Spent the last few days reading through this entire thread, Good read. Love watching the repair of little things that most would probably throw away! Did the HOA limit the size of your shop, or was that as big as you wanted to go?
Martin
F
Finallygotit
Tucson, AZ
Martin
Hi Martin, I applaud you for getting through this thread and thank you!
If I remember correctly, the HOA does have a size limit but I did not reach it. This was about as big as I wanted to go on this property. In my opinion, I did not want the building any bigger as I felt it would look out of place. My last shop was bigger than this one and all of that extra room just provided more storage for more ****.
:beer:
F
Finallygotit
Tucson, AZ
Well Rick, as of this writing, the floor coating is performing very well. Absolutely no evidence of any hot tire pick-up, cracking or delamination of any sort. So far, so good!
:beer:
Floor Update
Well..........this is not good. I have started to see areas on the floor where the coating is coming off. Those areas are where the vehicles are parked under the tires. Yep, we have hot tire pick-up. But this is absolutely not due to the work and products my wife and I put down. What we are seeing is bare concrete under the cracked coating. This is due to the original coating that was on the floor. The original product is not able to withstand hot tires. The original coating passed the tape adhesion test but I never knew if it would come off due to hot tires. Damn this *****!
First off, I kept a couple of small mason jars of base and hardener so I can touch up if needed. What I didn't retain was the clear-coat. I called Rustoleum on the off chance they might have a repair kits. As is turns out, they actually do have them for base coats BUT only if you put down their tan or gray epoxy. Unfortunately we custom colored ours. But, they do have clear-coat repair kits and, as it turns out, will ship those free to you.
So fingers crossed I have enough base coat to patch eight areas (I doubt it). But the clear-coat kit they sent is way more than enough.
Damn this royally *****!!!!
:beer:
F
Finallygotit
Tucson, AZ
That has got to be a tough pill to swallow, sorry to hear that. What is your plan going forward once those spots are repaired?
JB
DAMN that ***** Dan. I agree with JB, that's a tough pill to swallow and not an easy, quick or inexpensive fix.
Hi JB and Mike. Yeah, lately I tend to walk by those spots and flip them off. :fawk: Right now I'm going to just leave it be because I just can't bring myself to work on that right now. Phuckit for now...........
The plan down the line will be to rent a machine and grind the coatings off and get back to bare concrete. I will not be doing the whole garage as I don't see that as being necessary. I'm just going to work on the pads that the van and the Explorer get parked on. It's the hot tires that the original coating gives up on.
I will say this if anyone ever asks me, if you don't know what the coating is, don't waste your time and money putting down a new floor/coating. Grind it back down to bare concrete.
UGH...........
:beer:
RickP
Annapolis, MD
Floor Update
:beer:
That is a real bummer -- and too much work originally, to fail this soon.
I'm really sorry to hear that.
I hope you have enough original color to patch the 8 spots. If not, could you thin it a little to make it stretch?
rmack898
Honu Grove NE Florida
Sorry to hear about the floor Dan.
A few years ago we coated a very large service bay (4800 sq/ft) and we rented a machine to shot blast the floor. It was much faster than grinding and gave us a better surface for the epoxy to adhere to.
F
Finallygotit
Tucson, AZ
Mac, thank you very much for the info on the shot blast machine. That looks like a really good option. I have to see if someone around here rents those.
:beer:
