BryanPendleton
- Joined
- May 15, 2013
- Messages
- 14
I am working on a small weld/fab table design for my garage. While I would love a nice fixturing table with precision holes and all the matching clamps, but my projects are 1-offs, usually related to automotive racing or general home use, so I cannot justify a proper fixturing table, nor is it necessary.
That said, I have a 24"x36"x3/8" table top and I was planning to space it off from main table frame at 6 points. One this will allow me to fine tune and shim the table top for flatness (as the plate has a slight bow to it). Two I can build the frame to 24" x 36" since i don't need overhang which will promote table stability. Finally with the top spaced off I can use large throat C-Clamps, F-Clamps and pliers at pretty much any point around the parameter of the table top.
So my question is how far to stand the table top off? The larger the stand-off the more real estate I lose under the table, but I want to make sure I have enough space to accommodate all your typical welding/fixturing clamps and pliers. Maybe squeeze my arm under the table if I were to punch some holes in the top later on. What would be a recommended stand-off? 3"?
