Weld grinding
robertearl
Willow Park, Texas
I am repairing a Ford GPW jeep frame. The frame is a C section that is 4.5 inches tall. I have replace a large section of it due to rust and I can grind down the weld on the outside easily. The grinder wont fit into the inside of the C section to grind it down. I have looked for a disk smaller that 4.5 inches but have not had any luck. Any thoughts on how to get the inside ground flush. I would like it flush for the restoration of the frame.
Reb
metlmunchr
Plenty of discs available in 4" dia for 4" grinders. But you also have to have the 4" grinder because the hole in the 4" wheels won't fit on a 4.5" grinder.
I've got a couple 4's and a couple 4.5's, and I'd say I use the 4's 75% of the time over the larger ones.
jack stand
Lakes Region Maine
I'd use a new 7" or 9" disc on your big grinder, grinding with the edge of the wheel. You may be able to do this with a new 4.5" disc also but you loose visibility.
Com_VC
Australia
Die grinder with burr, they work better than the abrasive ones.
10mm, 20mm or 30mm air belt sander.
Angle die grinder with 3" disk as already mentioned.
matt_i
If you are looking to get a new tool, Milwaukee makes a corded "band file" which is a mini belt sander with a 1/2" x 18" circumference belt. Works very well in confined spaces. I used it to quickly remove the ERW seam-weld from square tubing (in short lengths of course) so they would telescope.
Also if you got a right angle die grinder (air operated, IR makes a miniature one, don't know the part number) you can use something like 2" roloc disks.
joe49
Tonica, Il
Couple of thought's leaving the inside the c section weld proud will be stronger. Did you angle cut or z cut or v cut your splice. If you straight cut, you should also fish plate the splice.
sberry
Brethren, Michigan
The real stress on a frame is on the flanges, web not so much. If it is 100 percent welded grinding flush can be good to relieve stress risers at the edge of the weld. This is important with stuff that flexes.
If I weld it right rarely plate.
