junktastic
- Joined
- Nov 24, 2014
- Messages
- 89
A good braze is just as strong, or stronger, than the base metal.
Just like a good weld.
Braze will flow all the way to the bottom/center/inside of that crack.
No worries of creating stress from welding.
Don't let it air cool. If nothing else, bury it in a pile of dirt to cool down.
How hot for something like that?If you mig weld it you will want to do some pre heating
Cherry red?
Oh OK, thank You.depends on the vise. the only one that cracked with no preheat out of a dozen or so I've welded was an older wilton. I ended up with 309 wire and a tig on that one mixed in with some 312.
I'm talking flux core wire, not copper wire with shield. that will crack every time. the flux provides a nice barrier.
If it was true cast iron, you'd need preheat, Nickel Rod and burry it in sand too cool slowly and peen the welded til you're purple to keep it from cracking. most usa quality vises are a form of cast steel, not cast iron. less carbon in cast steel and that is the brittle part that will cause cracking when the weld cools faster than the base metal.
a map gas torch, or even propane for a min or two will help also. no need to break out the torches and get it cherry red.
