Weld or Braze Ratchet Pawl
sometoyotaguy
Southern Maine
I picked up a older 1/2" Bonney US ratchet today at a yard sale.
Unfortunately, when I took it apart to clean it up, one of the pawls was broken.
Can I braze or Mig weld this?
rsanter
visalia ca
Doubt it. You may have some luck with silver solder. Welding I think you will find that the material will disappear or will be warped/shrunk beyond use
Bob
CJM8515
Would be better served paying a machine shop to make the part or finding a rebuild kit maybe.
ssdave
Eastern Oregon
No way a weld/braze repair would work and hold well. You'd be much better off making a new part. Or, much preferable to buy a rebuild kit or parts if you can find them.
If you want to repair yourself, buy a piece of tool steel the correct thickness, use a dremel tool and cutoff wheels to rough out the outline, file to shape. Probably a 2 hour job, maximum if you have any skill at all at this. If you have access to a drill press, you can drill numerous 1/16" dia holes along the outline and get a big jump start on the cutout. Or, if you have access to a vertical mill, you can scribe the outline, freehand out the outline, and then refine it. I've made numerous parts like this freehand on the mill. Not really cost effective for a $20 ratchet, though.
good luck!
dave
Carla
MEMBER EMERITUS
good luck!
dave
Concur......then remember that it has to be a heat-treated steel, preferably something like 4140, to withstand the loadings it would see in use.
In short, unless a 'repair kit' is available somewhere, its just not cost-effective to repair.
If you want to take up the project as a 'hobby challenge', mill the part from a scrap truck axle, which would be suitably good steel, albeit not so easy to machine......but it is 'do-able' if you are sufficiently determined.
cheers
Carla
bonneyman
Desert SW
Picture and model # of the Bonney rat in question? I might have a pawl buried in my ratchet stash.
garthg
Winchester MA
If this is a tool to use it's not worth the effort. You can get a very decent Snap on 1/2" ratchet on ebay for less than $30. Why bother, unless it's for a museum?
bodyguy16
QC, Canada
It wont hurt to try, as stated before if you can get it together strengh will be an issue. I say try it!
Greasymofo
dallas
Yeah go for it man, its worth a shot.. I too hate to see tools not being able to be used because of a minor fixable part
sometoyotaguy
Southern Maine
Now I'm confused? Two different ratchets in your pics? The third pic is a Kilness patent Husky CB-45 made by New Britain. Is you Bonney ratchet also a Kilness patent mechanism?
You're right. I mixed up the pics. There was another ratchet that I bought at the same time. Sorry about that.
More pics to come.
zkling
Just for kicks I might try some good epoxy and see what happens. Doubt it will work with much torque but, what do you have to loose at this point?
I feel as if I have seen that pawl design in a few different ratchets. Maybe you can source from a few different brands :headscrat
SCscoutguy
South Carolina
I wonder if any one here on the GJ has access to a laser CNC machine? I bet one of those could make you one of these real quick.
bodyguy16
QC, Canada
More than likely, BUT at what cost and of course one would either have to volounteer his/her time to design and machine the part. We have some generous members on here so you never know but i would stick to trying to repair before wishing upon one to machine a new one.
bonneyman
Desert SW
Ahh, the -702 series ratchet. Double pawl design.
Let me see if I have a spare pawl laying around.
