49 Fastback
I'm in a fix. I'm trying to repair a bad weld that I totally botched up on the underside of my welding cart. I can't get my grinder in to grind off the contaminated surface. What can I use to clean the metal?
I was thinking of a degreasing cleaner on a rag, and then work it with either a needle file or steel wool? Any other ideas? I think the reason my weld popped is because I didn't prep enough (it was the last weld on the table, I was in a hurry...lesson learned!)
Thanks
Tucker
Thanks
Tucker
