American Locomotive
...or just put on a plug 6-50 plug on it and call it a day, because it will be fine. Too many people take the code as gospel, when it has a ton of stupid things in it that are sort of inherently unsafe or don't make sense.
For example: It's not code to put a 5HP compressor on a 6-50R plug (even though it can handle the current perfectly fine) in the very slight off chance that someone yanks the plug while the compressor is running.
However, it's perfectly fine to have an unlabeled 6-50R outlet wired with 12 gauge wire attached to a 50A breaker for a welder. But when Joe-Blow gets chilly grinding some metal in the shop, he can unplug the welder, wheel this (https://www.amazon.com/dp/B09FX61B7G/?tag=atomicindus08-20) bad boy over and then immediately proceed to set my entire welding circuit on fire.
... or I replace my old AC-225 buzz-box with a 20% duty cycle with a shiny new Power Mig 360 with 60% duty cycle - and once again proceed to set my wires on fire because the previous owner of my shop wired this outlet with 12 gauge wire and never labeled the outlet as such.
