Looked at miller and lincoln today at machine welding and miller lincoln at national welders. found a Thermal Arc 3in1 welder at national welders/airgas and purchased it for 846.00 out the door (in stock MGR special). 1200.00 sticker price. The Thermal Arc 181i is a 3in1 process machine mig tig stick and spoolgun for dc alum. Actually talked to a guy(welding Instructor at local comm. college) that had it first and he highly recommended this machine. So I bought it. Guy behind me ordered one also. Victor being a name brand I didn't see a reason for not buying it. I'm happy and thanks for all the input.
Can't wait to get it set up. It is comparable to a miller 200 MP available for 2000.00 Here is the specs;
SPECIFICATIONS
Maximum Output 180 Amp
MIG (GMAW/FCAW)
Welding Output @104˚F (40˚C)
180A / 23V @ 20% Duty Cycle
145A / 22.5V @ 30% Duty Cycle
STICK (SMAW)
175A / 27V @ 20% Duty Cycle
140A / 25.6V @ 30% Duty Cycle
TIG (GMAW)
175A / 17V @ 25% Duty Cycle
160A / 16.4V @ 30% Duty Cycle
Current Range 10 - 180 Amp
MIG Welding Voltage Range 10 - 25 Volt
Wirefeed Speed Range 100-650 IPM (2.5 - 17.8m/min)
Maximum Plate Thickness 1/4" (6.4mm)
Wire Diameter Range
Mild Steel: .023" - .035" (0.6 - 0.9mm)
Stainless Steel: .023" - .035" (0.6 - 0.9mm)
Aluminum: .030" - .035" (0.8 - 0.9mm)
Flux cored: .030" - .045" (0.8 - 1.2mm)
Installed Feedroll Suits MIG Wire .023" - .030" (0.6 - 0.8mm)
Warranty Period 3 Years*
Approvals IEC 60974-1 (CE)
Protection Class IP23S
Dimensions H x W x D H 16.14" x W 8.27" x D 17.72"
(410mm x 210mm x 450mm)
Weight 32.2 lbs. (14.6 kg)
Primary Power
Primary Voltage 208/230 VAC
Supply Voltage Range 208 - 265 VAC
Number of Phases Single Phase
Supply Frequency 50/60Hz
Supply Plug NEMA 6-50P
Rated kVA @ 180 Amps 9 kVA
Lead Cord Length 9 ft. (2.75m)
Maximum Input Current 37 Amps
Replacement Items
& Consumables
Tweco® WeldSkill® 180 Amp MIG Gun, 12 ft. 1017-1316
Nozzle 1/2" Bore 1210-1112
Diffuser 1510-1101
Liner 1420-1113
Contact Tips Tweco 11-Series
Tweco WeldSkill 200 Amp Electrode Holder
w/Lead, 13 ft., 50mm Dinse
WS200E13
Tweco WeldSkill 200 Amp Ground Clamp
w/Lead, 10 ft., 50mm Dinse
WS200G10
Victor® CutSkill® Argon Regulator/Gauge 0781-4169
Gas Hose, 12.5 ft., Male 5/8-18UNF W4013900
as for the air compressor tool discount .com has the 2 stage ingersoll rand 80 gal for less than 900. bucks I think if anyone is looking I will be as soon as I build a new shop.
Tim
