- Location
- Ohio
- Price
- 4,500
Welder, Plasma Cutter, Generator, Hobart Champion Fabshop
Like new (total of 15.7 hours) on this Welder. It is a 250 amp constant current air cooled, gas drive AC/DC Welder/Generator, Plasma cutter with build-in Air Compressor. It is capable for the following processes: Shielded Metal Arc (Stick), Gas Tungsten (Tig) and Plasma Arc Cutting. It furnishes 8500 watts of single phase, 115/230 volt 60HZ AC auxiliary power. Comes with 50 ft. Plasma Torch. Build in Air Compressor is capable of approximately 7CFM at 80 psi continuously for use by the Plasma Cutter or Air tools. It also comes with over a $1,000 dollars in spare parts including an extra 20 ft. Plasma Torch, spare PC Boards, Torch Heads, Brushes for the Generator, Tips and Insulators. A complete welding shop on the back of your garage, truck or trailer.
