Welder Output Amps
zendriver
Indiana
I have a self darkening welder helmet that has shade adjustment knob. There is a chart for it's shade setting based on welding method and arc current, in amps.
What is the way to determine about how many amps the welder would be using?
Thanks
PCustoms
VT
Thanks
Isn't there a chart on the welder door?
When in doubt, turn the helmet up and then slowly back the setting down.
Z
zendriver
Indiana
It depends on the welding process and what you are welding. Automotive sheet metal welding?
Different weld output than welding 2" structural steel plate.
It would be flux wire on some scrap sheet metal or thin angle pieces.
Just starting out, mostly.
PCustoms
VT
yes but I could find nothing that referred to amps. It's a MigMax
What's your range on the helmet?
Likely set it to 10 and adjust from there.
One thing, so I've read, is the helmet always blocks the dangerous UV. You might get flashed it it doesn't darken, but it's not permanent.
Jack Ryan
Adelaide, South Australia
It is just a guide, different people have different sensitivities to brightness.
This table gives a range, and it is pretty wide. You could start with 11 and work down.
The shade adjusts the brightness of the ARC, not the UV content. The UV content should be removed irrespective of the shade.
It is a matter of comfort, not burning your eyes.
Jack
Z
zendriver
Indiana
Shade range is 9-13 Amps range 10-500 depending on welding method
PCustoms
VT
Set it to 11 (hehe) and dial it in from there.
Get a good light close to your work, or fancy flashlights mounted to your helmet. Makes a world of difference.
Jswain
Calgary, AB
Download the miller welding app. Not to use it for your settings but it will give you an amperage range for the material thickness. Then you'll have an idea how many amps you're welding with if you're sticking with the door chart on your machine
It won't be exact but a ballpark
dnschmidt
Phoenix, AZ
This setting is very much dependent upon your eyesight. I have very light insensitive eyes so I need a lower setting to see anything than most people do. Typically for MIG I'm somewhere between 8 and 9. For TIG between 9 and 10.
GaryM909
Calgary, Alberta, Canada
When I was working in shops I used #11 all day long for Mig, Tig, Stick. I would use a #12 for Dual shield. Outside I used a #9. In my garage at home I use #9 or #10.
I have worked with people that are using #12 or #13 in the shops and others using #9 for everything. Everybody is different. If you are seeing light spots or if your eyes get sore you will need a higher # shade. #10 is a good starting point.
welder4956
Birmingham, AL USA
Assuming you are using MIG since there is no amp control, just wire feed speed. The knob on most hobby welders only has settings from 1 thru 10, so to estimate wire feed speed you would need to cut the wire flush with the contact tip, pull the trigger for 5 seconds, measure the inches of wire past the contact tip, then multiply by 12 to get the number of inches per minute. Once you have the wire feed speed, you can estimate amps from the chart below:
However, the shade selection is really a matter of comfort as others have stated. Start with a shade setting of 10 and adjust from there. If it's too dark, go lighter. If you start experiencing eye discomfort after welding all day, go darker.
