paul2112
Does anyone make a replacement power-cable for a welder 220V with a premolded end,say 5' long? Thanks
Welders come with 50. I clicked on the link for giggles, yes, way pricey.Depends on what type of outlet you have. 30A, 50A or ??
A range cord is not a welder cord.
How is a range cord different than a welding machine cord, as long as they are V and A compliant?
Ranges and welders use different receptacles.
Only if they differ in their voltage or amperage needs. Besides the need for a twist-lock, there is no other reason for differences in configurations. Most ranges are 120/240, while welding machines are most often 240, but we don't know what kind of machine the OP has.
Most is not all. What part of that don't you understand?They do differ in their voltage requirements, you stated that in your own post. What part of this don't you understand? You are only adding unnecessary confusion to the OP's thread.
You're a lost cause.
The OP already mentioned he needed a cord with a 6-50P on it. If you want to try and prove there is a range out there somewhere that uses the same cord, have at it.
I'm out.
