ducatithunder
I was reading through my manual today regarding feeder wire size. Before I start pulling the wire I wanted to confirm my thoughts with some of the forum electricians.
Background info ... My receptacles are all under 100ft from the panel. This is the biggest welder in the lot so the others should be covered it this is good. The plug on the machine is a 6-50 so Im using 6-50R plugs.
Just wanted to confirm that I am reading this right. Im running single phase 230V.The 40% Duty Cycle on this machine is 250 @ 52Amps with the 115v loaded 120V aux loaded.
From the chart they list 75Deg wire @ 10AWG for under 100ft. Im running NM wire so in order to cover the amp draw on the 60Deg chart I should be using 6AWG correct? I doubt Ill ever hit the DC on this machine but wanted to make sure it was right the first time.
Ive attached a picture of the manual below. Thanks.
