welding a bimetal hole saw
The Cobbler
I have a large bi metal hole saw where I inadvertently stripped out the threads where the mandrel goes in ( didn't have the pins set in place)
would an easy repair would be to weld a cap on from another hole saw? is there anything I need to know since it's hardened?
thanks
Com_VC
Australia
If you have a spare or old arbour you could also tack weld that into place and just leave it there permanently.
matt_i
There are the issues with concentricity...its good to use a lathe to do your best work there.
However, I think you could do a decent job if you had tightly fitted pins that aligned the two drive-holes, and weld on another center-section to the existing one.
AA/FC
I have done exactly what you're talking about, for the same reason that you're talking about.... I didn't have any problems. It's just a hole saw. You can't ruin it any worse than it already is. Go for it!
bad_idea
Pasquotank, NC
Done that countless times at work. Running a hole saw through a bulkhead or deck, it catches, and strips the threads on the hole saw. Have the welder throw couple tacks on it and keep going. Hole saws and arbors are a consumable item for us. I imagine you could cut the tacks and keep the arbor if you can get the hole saw off of it.
T
The Cobbler
not all that concerned with concentricity . they run at slow speeds, and I can alingn it well enough with a bolt thru the pcs.
I could use an arbor but then it takes up more height (not a big deal) but I do have several toast hole saws that I could get the cap from. also this is a 4" hole saw, barely used and i'm cheap!
racingtadpole
The far side of crazy.. but sometimes Australia
It’s Bi Metal, so only the teeth are hardened (marketed as a feature but reality is it’s a manufacturing cost efficiency).
Me, I’d weld the thread up chuck it in the lathe to bore it for new threads. If I didn’t have a lathe I’d probably look to a drill press. Use the arbor to centre it, then clamp it and drill for tap size
