welding cart/cooler project
charger891
manitoba
welding cart/ tig cooler project
Finally had time to finish my welding cart,/tig cooler combo, the cart was basically built from scraps around the shop, the bottom portion was actually a cart i built years ago for my snap on bottom toolchest, couldn`t find a pro con pump in my area so i bought a 115v sprayer pump, used a fuel tank off a golf cart for the resevoir, condenser off a 89 crown vic, long 220v extension which i then installed two 115v plugs, for my mig and cooler, i`m also going to add a extension cord reel on top so i can use that for grinding.
View media item 14119View media item 14114View media item 14115View media item 14116View media item 14120View media item 14118View media item 14124View media item 14123View media item 14121
Ifixvws
Minneapolis, Mn
Like the cart. I have an old tig cooler that has a small leak in the core and the pump is dead.
What do think about the plasma cutter you have. I have been looking at a hypertherm but the cost is... Well costly.
gixer007
Va
I have a Powermax30 From Hypertherm.
Love it. Wish I had gotten one sooner.
Steven
C
charger891
manitoba
The machine is actually decent, the stick welder works as good as the lincoln we have at work, the plasma had issues from the get go, they sent the wrong tip size with the machine, now i have the right tip it works like a charm, i`ve looked for used tigs and plasma cutters in my area for a year and couldn`t find anything, this machine fit right into my budget.
