Oxy,argon, and mix tanks can be as low as 1800 if they were filled from a manifold.A lot of places will fill this way instead of sending them back to a filling station that has a pump.What they do is connect 3 or 4 tanks on a daisy chain with the first the "fullest" and the last "empty". As the tanks equalize out,they are swapped back up the chain,and the formerly "full" tank sent out.They can "fill" 3 emptys from 3 fulls and get 6 to send out,but they will only be at 1800 instead of 2200.
Acetelyne tanks are sold by volume,not pressure. They are filled with cotton saturated with acetone,this absorbes the acetelyne gas. There will always be a chalked number on the side of the tank that tells how much was put in.I always sort thru and find the "heavy" tank, since the price is the same.
edit) bottom line is that if your getting low pressure tanks all the time,find a new supplier thats not stealing from you. We would do this with ourown tanks if we were getting low on numbers or needed one for a service truck that was mt,but we were stealing gas from ourselves,a different thing altogether!
